Oil leak?
Old Jul 10, 2010 | 02:22 PM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
Oil leak?
well i just got my camaro running on thursday i put new carb a new alternator a new pair of valve covers and an egr block off plate. instead of using studs i used the y wing hold downs i went through at least a quart of oil since then so anyone wanna give their
edit
i had a leak at the passenger valve cover that i fixed yesterday before work but i am still leaking oil from my passenger side somewhere =/ i cant find where exactly cause im not under the car when its leaking
Old Jul 10, 2010 | 03:47 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Oil leak?
If you are still leaking oil from the passenger side, check for a leak where the dipstick tube goes into the block.
Old Jul 10, 2010 | 04:00 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Oil leak?
could be dipstick,intake gasket didnt sit properly, oil pan gaasket etc etc
Old Apr 10, 2011 | 02:32 PM
Car: 86 z28
Engine: 305ish
Re: Oil leak?
was the oil pan gasket in the end... now my valve cover on the passenger side is leaking i think? im checking the dipstick first because i dont belive i messed up the gasket on my valve cover three times but my carb ate its gasket today =D fun
Old Apr 10, 2011 | 09:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Oil leak?
Using rubber or cork valve cover gaskets? Did you thoroughly clean the old gunk off real well? None of those fancy chrome valve cover bolts ever work well, they twist inside rather than tightening down.
Old Apr 14, 2011 | 12:13 AM
Car: 86 z28
Engine: 305ish
Re: Oil leak?
i used cork and i hit it with a wire brush until it was all off like it was shiney metal i put the gasket onto and the chrome hold downs i guess could be the problem but idk cause i still have the same thing holding it down its like a spacer i guess? idk but as of today the camaro isnt on the road i bought a 2000 jetta so its either gonna be really good for my camaro or bad for it idk yet
Old Apr 14, 2011 | 12:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil leak?
You took the smog pump off, didn't you?
Old Apr 14, 2011 | 01:26 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Oil leak?
Could it be from the sending unit?
Old Apr 14, 2011 | 09:33 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil leak?
No sending units on the passenger side.
Old Apr 14, 2011 | 09:50 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Oil leak?
Did you use a good adhesive sealer like KW Copper Gasket Sealer or Permatex High Tack to affix the gaskets to the covers and let it set up good before assembly? If not the soft cork gaskets may have slipped out of place. You can go around the cover with a dentist's mirror to look for cork all the way around. The Felpro silicone rubber on a steel frame are so much better because they hold their shape and stay put.
Old Apr 15, 2011 | 11:42 PM
Car: 86 z28
Engine: 305ish
Re: Oil leak?
well the smog pump was removed prior to me getting the vehicle so yep its been gone for a good 5 years prolly
Old Apr 15, 2011 | 11:56 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: Oil leak?
Apeiron will tell you to check the front, lower portion of the engine block. One of the holes that the smog pump mounted to goes through the block into oil. I've had oil come from this hole before when it was left open. If this is the case, put a short bolt(3/4") with a ring of RTV on the threads into the hole to plug it. Thread size is 3/8-16.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
