Iroc Timing And Issues
Old Jul 11, 2010 | 04:20 AM
cdm61093's Avatar
Car: 1998 IROC-Z
Hello I have a 1988 Iroc-z 350 TPI. I am having a problem with my car which shows a code 23. And sometimes the car will not idle till I shut it off and restart it. I am wondering what i should have my base timing set at? I live in colorado at an elevation of 5280 feet. Currently I have set my base timing to 10 degrees before top dead center, But after that I installed a Jet Performance Chip. So would that cause any problems such as being too advanced or retarded? The only other modifications this car has are twin 58 mm throttle bodies, 2.5 Inch exhaust with no catalytic converter or mufflers. Thanks
Old Jul 13, 2010 | 04:24 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Iroc Timing And Issues
Uhm id defintiely go for factory timing specs here, the wonder we call obdI has variables for elevation unlike carbs used to. Id set it back to factory spec and go from there, make sure you're going thru the proper steps with the est wire too or you'll be battling the ecm for a while
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
86Base
Aug 8, 2015 01:34 PM
