car died
car died
I own a 91 trans am it was running great one and I made a stop at a store and it wouldn't start I took it back to the car lot that I purchased it from and they have replaced injectors, cap and rotor, wires, computer and sensors and are still having trouble I'm wondering if it might be o2 sensor (master airflow) we are at the last resort please help if anyone can
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: car died
that wouldnt cause a no start, check the ignition switch and the VATS module, either could be causing you trouble. Look up vats procedure and the ignition switch on a search
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: car died
If it turns over, then it's not necessarily VATS.
Did anyone pull codes? https://www.thirdgen.org/service-eng...ht-error-codes
We need alot more info. What induction? Does it crank but not run, or does it not even crank at all. Auto or 5sp? Anyone test the Ignition Control Module in the dist cap? What is the fuel pressure?
db057
Aug 11, 2015 10:11 PM
