To be or not to be (Internal or external balanced)
Old Jul 25, 2010 | 08:08 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
How to correctly tell if engine is externally/internally balanced?
If it's external, then my balancer would have a weight on the inside as well as a weight flywheel correct?
Old Jul 25, 2010 | 08:24 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: To be or not to be (Internal or external balanced)
yeah, basically.
Old Jul 25, 2010 | 08:34 PM
Originally Posted by Atilla the Fun
yeah, basically.
So, if it's internal. Then no weight on balancer and no weight on flywheel?
Old Jul 25, 2010 | 08:52 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Correct about the damper, but with the flywheel or flexplate, it's complicated with the 1-piece-rear-main-seal engines.
for the '87-up blocks, most stroker cranks, whether internal or external balance, still keep the stock rear external weight, just so you can use any stock-style flywheel or flexplate.
Also confusing the issue, there are stealth dampers available that hide the external balance. These are easy to find on Speedway's website.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
scottmoyer
Sep 7, 2015 07:06 PM
