Fuel Pump
Old Jul 30, 2010 | 12:03 AM
JayBallard's Avatar
Fuel Pump
i have a 91 firebird with the 5.0 is there anyway to do the fuel pump without dropping the tank
Old Jul 30, 2010 | 08:53 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Fuel Pump
Do a search, there's ways but you have to cut up the body, I say just get at it its not that hard to drop a tank
Old Jul 30, 2010 | 06:26 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Fuel Pump
If you cut the hatch area to make an easy access hole, you'll have to cut all 4 lines of the sending unit and install high pressure hoses. Ive seen it done but I recommend you doing it the right way. Dont be lazy. Get dirty and getter dun. Plus you'll get to clean out the tank.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
