Starting Problemsss!
Old Aug 13, 2010 | 12:29 AM
Tank91RS's Avatar
Car: 1991 Camaro RS
Engine: Carb 350ci bored .40
Axle/Gears: 2.73:1
Ive been trying to figure out why my car wont catch.
Its not popping so i know the starter is fine.
I can just hold the key and it just wont kick.
Any ideas?
Its a pretty mistreated car, should I try changing some sensors and relays?
Old Aug 13, 2010 | 09:07 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Starting Problemsss!
Are you saying the motor just spins over, but no fire? Have you checked to make sure it's getting fuel and spark?
Old Aug 13, 2010 | 09:37 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: 2.73:1
Yea exactly.
Umm im kinda new to the mech. thing.
Little more detail on how to check that would be great!
Old Aug 13, 2010 | 09:55 PM
jtsk's Avatar
You can pull a plug out and hook the wire back up, have someone spin the starter and ground the plug to the manifold to see if it is firing. If it is, then check to see if you are getting fuel to the throttle body, also check the fuses to see if the pump fuse or any others are blown.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
