Accelerating problem
Old Sep 17, 2010 | 12:37 PM
PontiacMC's Avatar
Car: Trans Ams
This is kind of hard to explain but I will try. On my 88 305 TPI GTA the car runs great untill I try to go....When I just give it throttle(no matter how much), from idle or not it hesitates really bad. If I pump the throttle once or twice it is fine and runs fine. If I am just cruising and I give it throttle you barely notice it untill it all of a sudden picks up and goes.....Kind of like it has VVT. It doesnt effect the way it starts or under WOT, I havent had this car that long and this is the first TPI I have owned so if this is normal I would just like to know and I guess I will live with it.
Old Sep 17, 2010 | 10:28 PM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
Re: Accelerating problem
Sounds like the throttle position sensor
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
