89 305 TPI still won't start
Old Sep 24, 2010 | 06:43 PM
smartnluckie's Avatar
Car: 1989 IROC Z
Engine: LB9 5.0, TPI
Transmission: 5 speed manual
Axle/Gears: 3.45
So I am posting again about my 89 vert with 305 TPI still not starting. Her eis what I have replaced based on recommendations:
Cap, rotor, plugs, plug wires, ingnition module, manifold temp sensor, MAF sensor, coil, fuel filter.
I was reading a post today and think my problem may be the injectors. The car will start with starting fluid no probalem and ide for as long as I want it to run. When I turn it off then there is no restart, cold or hot. So I OHM tested the injectors today, readings as follows:
CYL 1= 11.9
CYL 2= 13.4
CYL 3= 16.7
CYL 4= 9.3
CYL 5= 16.8
CYL 6= 16.8
CYL 7= 5.5
CYL 8= 9.1
In my calculation I have 4 bad injectors. Should be a no brainer that was probably my problem the whole time. Just looking for some input. I have already dumped some money on parts that probably didn't need it, but oh well they are in there now. Could this be the last fix for now to get her running?
Old Sep 24, 2010 | 06:52 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 89 305 TPI still won't start
Sounds like a plan. Be sure to check fuel pressure too. About 40 PSI when cranking.
It sucks throwing parts at a car doesnt it? Thats why we try to diagnose the problem before buying parts.
Old Sep 24, 2010 | 10:41 PM
Car: 1989 IROC Z
Axle/Gears: 3.45
Thanks doc, i forgot to throw that in, rail holds steady 40lbs key on, cranking and running. I do hate changing parts with no result. And most of the parts were by other people lkooking at the car and testing them saying replace that it will fix it. Car had been sitting for a long time so probably didnt hurt changing it all in the long run.
Old Sep 25, 2010 | 06:58 AM
southbay08's Avatar
you are correct, ditch the injectors and get yourself a set of bosch lll's.
Old Sep 25, 2010 | 07:36 AM
Sighman's Avatar
I had the same problem, new injectors and she runs like a dream now! Check out southbayinjectors, gave me a great deal on bosch's.
Old Sep 25, 2010 | 09:34 AM
Car: 1989 IROC Z
Axle/Gears: 3.45
Southbay...Looks like you're the expert on these, I gotta get some money together but what kind of cost am I looking at for a full set of 8
Old Sep 25, 2010 | 09:53 AM
southbay08's Avatar
PM sent
Old Sep 25, 2010 | 04:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
DITTO
Old Sep 25, 2010 | 08:56 PM
mlopezformula's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: 3.43
I had the same problem the car would not start, only if I sprayed starting fluid in it and it would start. later i figured out that it would start if I disconnected an injector. I figured out by feeling the injectors click that something was wrong with them, then I checked my fuel pressure and filter and it had black contaminated fuel was coming out of it. so the tank was still dirty and clogged the injectors so I put in sea foam in it and within 3 days the car would start. I still might need new injectors though.
Old Sep 26, 2010 | 01:48 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
mlopez, sounds like you will need to drop your tank and flush it along with your fuel lines. Check your charcoal canister for signs of failure. Its not uncommon for the charcoal cells to rupture releasing charcoal particles into the vapor lines. The particles may have made their way into your fuel tank.
Old Sep 28, 2010 | 09:12 PM
Engine: LB9 305 tpi
Axle/Gears: 3.43
Ok Ill check thanks!!
Old Sep 28, 2010 | 09:21 PM
southbay08's Avatar
Seafoam is a great product, although we offer flowtesting service we also carry seafoam. It is one of the most reputable additives out there and it does a great job cleaning out your fuel system but whatever dirt gets flushed through the lines utimately ends up into the filters of the fuel injectors.
Old Oct 1, 2010 | 12:19 AM
Engine: LB9 305 tpi
Axle/Gears: 3.43
Does the fuel Injector machine clean them?
Old Oct 1, 2010 | 06:57 AM
southbay08's Avatar
The bottom line is that the most reliable and efficient way to clean fuel injectors is to have them cleaned and flowtested.
When we service injectors, before they are flowtested, they are placed into 2 high temp ultrasonic baths, and then they are reverse backflushed, then they go through the rest of the flowtesting process.
The benefit to having injectors cleaned and flowtested is that we are able to visualize the quality of the spray pattern and we can leak test them up to 80 psi. We also replace all filters, orings, pintle caps and spacers with new parts.
Although the fuel additives work there is no way of obtaining any of this info unless they are placed onto a bench.
Old Oct 1, 2010 | 05:15 PM
Car: 1989 IROC Z
Axle/Gears: 3.45
Hey guys this is all great info, thanks to everyone, I am hoping this solves my problem, I have ordered the injectors and can't wait to get them in
Old Oct 9, 2010 | 08:20 PM
Car: 1989 IROC Z
Axle/Gears: 3.45
Well, I received my injectors, installed them today and looky there the car starts right up. Thanks guys for all your help, one last thing I need help with until the next thing of course. It says on the hood tag to set timing at 6 degrees, but in the manuals and eveything I have looked at so far it doesnt reference a RPM to set the 6 degrees at. Can anyone help?
Old Oct 10, 2010 | 08:10 AM
Sighman's Avatar
That's great news, I set mine to around 750 (manual trans). Make sure you pull the wire for the distributor advance (mine was in front of the blower motor for the heater - single brown wire with a butt connector).
Old Oct 16, 2010 | 09:13 PM
Engine: LB9 305 tpi
Axle/Gears: 3.43
I just checked and my #3 injector has 1.5 ohms the rest are between 14.5 to 16.6 looks like the injectors were the problem after all...........
Old Oct 17, 2010 | 12:01 AM
Car: 1989 IROC Z
Axle/Gears: 3.45
replace em all, southbay injectors, great deal, great injectors...my understanding they should all be within .5 ohms on the reading
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
