Will these work?
Old Nov 12, 2010 | 06:07 PM
MustangTamer's Avatar
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
Will these work?
http://www.worldcastings.com/product...ron-heads.html
have a local guy on craigslist that has these cheap. i have an 89 L98 bird and im not sure if everything will line up correctly. thanks for any answers
Old Nov 12, 2010 | 06:59 PM
Twin_Turbo's Avatar
Re: Will these work?
Yes, only issue is they are set up for 90 deg. intake bolts, not 72 deg. middle ones. Nothing a little grinding won't fix.
Old Nov 13, 2010 | 10:02 AM
Axle/Gears: 3:27
thanks! i just hope everything seals right after grinding.
Old Nov 13, 2010 | 04:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You just have to 'ovalize' the two center bolt holes on each side of the manifold. There are special angled washers you should also be using, but I can't remember who makes them now. They are intended just for this exact thing.
The other thing you can do is find an '85/86 F-body intake base, or one that came off a Corvette with the aluminum headed L98. Both of those used the old-style bolt pattern where all the bolts are at 90* like those Sportsman heads are.
Either way should work just fine.
Old Nov 13, 2010 | 05:51 PM
Twin_Turbo's Avatar
The corvette has a header fed EGR system.
Old Nov 14, 2010 | 01:34 AM
Air_Adam's Avatar
Ah right I forgot about that... I'm not having a good day here lol.
The early base will bolt right up, or you can grind out the holes in your existing base.
Old Nov 14, 2010 | 08:22 AM
Axle/Gears: 3:27
thanks guys but it looks like im out of luck. someone got to them before me. dang
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
