speedometer not working???
Old Feb 8, 2011 | 09:32 AM
speedking1995's Avatar
Car: 1992 camaro rs 25th anniversary
Engine: 305 TBI
my speedometer isnt working it just jumps every now and then and all of my other gauges work can someone help?
Old Feb 8, 2011 | 01:41 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speedometer Says 0? KEEP IT FLOORED !
Most likely an intermittent signal from the VSS.
To find out monitor the speedometer signal with an audio amplifier to make sure it’s getting a steady signal.
Connect the amp’s input to the
gray wire pin 8 going to the dash at the dash connector on the right as you would a CD player.
Ground to ground, the signal wire to the inner wire of the audio amplifier wire.
The next time the speedometer fails note if the signal stopped.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Feb 8, 2011 | 03:05 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: speedometer not working???
Check the vss wiring connection on the transmission tail shaft. It may just be a loose connection or one of the wires at the connection may be open just enough to intermittenly send signal. Have had both occur.
Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
