fried pistons?
Old Feb 9, 2011 | 02:54 AM
5.7chevykid's Avatar
Car: 82 berlinetta camaro
Engine: 350 5.7
Transmission: auto
fried pistons?
when ur running on less pistons do you just buy new ones and install them or does it require more work in the block
Old Feb 9, 2011 | 10:41 AM
WESTOF7's Avatar
Re: fried pistons?
why do you think your not running on all cylinders?
Old Feb 9, 2011 | 06:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: fried pistons?
To answer the question - you should replace them all as a set, and to do it properly requires machinework on the block to make the rings seat properly.
Why do you think you have a 'fried' piston? Whats going on?
Old Feb 10, 2011 | 08:42 PM
Engine: 350 5.7
Transmission: auto
Re: fried pistons?
just not not getting the power and it sounds it il post a sound clip
Old Feb 10, 2011 | 09:37 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: fried pistons?
why not do a compression test?
and if you change one piston you have to change them all... the difference in a fraction of weight will cause horrible vibration.
Old Mar 4, 2011 | 11:31 PM
Engine: 350 5.7
Transmission: auto
Re: fried pistons?
http://www.youtube.com/watch?v=Uq-GR3WC8hM its low on fuel too
RedLeader289
May 28, 2019 01:47 PM
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
