85-92 305 350 TPI Sytem forsale!
Old Mar 13, 2011 | 06:27 PM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
came from an 89 camaro with a 350 Tpi, 24LB injectors over the stock 22LB
bigger Throttle body, new TPS, newer injectors, High-Flow Runners
comes with
upper intake (red)
lower intake (grey)
runners (silver)
all 8 injectors (Blue)
fuel rail (silver)
New TPS
Throttle body
all bolts and screws needed
throttle bracket
throttle cables
temp wires
eveything execpt ECM and wiring Harness
i also have a Mass air Flow sensor too for extra,
along with the tpi air intake system, rubber boot and the y shapend air intake.
or i also have a cold air intake for extra aswell,
pics on the system alone and how it would look on your tpi car below,
(please not the runners are black in the other picture as that is my current 86 TPI vert camaro)
im asking 450$ for everything minus the cold air intake system.
the reason im selling is cause my old camaros ECM went out and i replaced it with a carb, so i dont need this system anymore...
large pics below
and sorry for posting this here, i cant find anywhere to post it forsale, i remember seeing a forsale thing on here but i cant seem to find it, if someone could give me a link i would apreciate it,
Thanks, Bob
Old Mar 13, 2011 | 07:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 85-92 305 350 TPI Sytem forsale!
It's called the Classifieds.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
