went to pull car outta storeage, it won't start
Old Mar 20, 2011 | 09:22 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
friday i went to go pick my car up outta storage. it's about 45 min away in a buddy's garage and i wanted to get it home and start doing stuff to it.
i get in the garage and hook the battery up and make sure i get all the steel wool outta the engine bay and moth ***** and such. turn key on, i hear no sound of fuel pump. that isn't good. turn car over, and it doesn't start. not even a cough. tried to spray some starting fluid in the intake, and that didn't even do anything.
didn't have any spark coming from the wires. i left it for the night because all i had planned to do was start it and drive it home. wasn't expecting to have to do ****.
go back today, clean off the cap and rotor, check fuses, check connections, and check fuel pressure. finally got spark at the wires, but 0 fuel pressure. got the vehicle to start of intake cleaner, but it only ran for a second.
also my SES light doesn't even come on at start up when it's supposed to do a self diagnostic. wtf? always used to.
factors to keep in mind:
battery was on trickle charger all winter
car ran before it was stored
moth ***** covered the garage, and no signs of critters
used stabil in the fuel take and ran it through the lines before shutting it off
tank is 3/4 full
fuses were good
anybody have any ideas? i'm leaning towards fuel pump.
Old Mar 21, 2011 | 07:20 PM
Engine: 350 L98/LS2
Re: went to pull car outta storeage, it won't start
somebody has to have an idea...............
Old Mar 21, 2011 | 07:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd check the fuel pump relay, and it's connector. If that's good, then I'd stick 12v+ directly to the fuel pump wire and see if it runs - if it does, then your back to the relay, if it doesn't, then you have a dead pump.
Old Mar 21, 2011 | 08:38 PM
Engine: 350 L98/LS2
ok.
what would be your guess on why my SES light doesn't show up?
Old Mar 21, 2011 | 08:49 PM
Car: 1992 RS
Engine: Carbed 350
Not sure on that one. Missed that part of the question.
Have you looked at the ECM, and it's connector of wires? I know you did the mothball thing, but maybe someone chewed into the ECM harness for a snack - that would explain the no start and no SES light.
Old Mar 21, 2011 | 10:36 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Originally Posted by blackbeauty89
ok.
AFAIK a dead fuel pump will not trigger SES.
I could be wrong, though.
Old Mar 22, 2011 | 12:31 AM
Engine: 350 L98/LS2
i'm just saying in general the SES light won't illuminate. it's supposed to and also used to when ever i'd turn the key to "on". i also plugged in my ALDL reader to check to see codes, and there was no flash of the SES light at all. key was on.
i haven't checked out the wires around the ECM.
Old Mar 22, 2011 | 07:52 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
yea start with fuses and relay and putting power at the fuel pump relay to see if the pump will run. I wouldnt worry about the SES light right now cause your trying to get it to run and you need 3 things spark, fuel, and compression and your lacking fuel so start with verifying your pump is good.
Old Mar 24, 2011 | 12:30 AM
Engine: 350 L98/LS2
how reliable is hitting the fuel tank with a hammer? lol
Old Mar 25, 2011 | 12:06 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
SES light not coming on, i would think its the ECM...check the fuse
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
