Mass Air problem
Old May 20, 2011 | 12:17 PM
Dillanmiles's Avatar
Car: 1986 trans am. T-top
Engine: TPI 303
Mass Air problem
I have an 86 trans am with a tpi 305. the check engine light is showing code 33 and 34. I believe 33 is low voltage to the maf sensor. and code 34 is high voltage to the maf sensor. what could this be??
Old May 21, 2011 | 09:19 PM
Tommy R's Avatar
Re: Mass Air problem
try changing the maf power relay, that should fix it and check connection to maf sensor is tight
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
