Setting The Timing Help
Old Jun 5, 2011 | 12:24 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
I need help with the timing. Yes I read the thread on how to set it when the car is running fine, but how about if you cant start your car. On the sticker is says to set it @ *6 BTDC and I was wondering if its possible to set it even though i cant start the car.
Old Jun 5, 2011 | 12:43 AM
elpulpo's Avatar
Re: Setting The Timing Help
Well if the car does not start is ignition or fuel problem
Old Jun 5, 2011 | 12:45 AM
elpulpo's Avatar
Cant set timming if engine is not running
Old Jun 6, 2011 | 05:06 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Probably so far off that it won't start. Need to get your #1 to TDC and start from there.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
