Starting trouble
Old Jun 5, 2011 | 09:29 AM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Starting trouble
I've got an 89 GTA and the car gives me trouble when starting sometime, especially when it's warm after running a few minutes ago. The longer it sits, the less problems it gives.
So basically the car will crank over but will sometimes it will sputter, start running rough, and then cut off. Other times the RPM's will dip real low, the check engine light will come on, the RPM's will shoot up to like 1200, the check engine light will go off, and it will begin to idle normally and the car will be fine. All of this only occurs immediatley after startup.
I am pretty sure my fuel pump is not the culprit because once my car is running it never gives me any trouble.
Any ideas? I was thinking ignition coil, knock sensor, O2 or MAF sensor. Any input would be great! Thanks.
Old Jun 5, 2011 | 02:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Starting trouble
Might try ignition module inside the distributor.
Old Jun 6, 2011 | 08:16 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Any chance of bad plugs or wires? I'm thinking I'd notice bad plugs when I was driving as well, not only at startup. But thanks, I'll check out the ignition.
Old Jun 23, 2011 | 02:06 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Used an OBDI scanner and was lucky enough to grab the code. Bad MAF sensor. Now I've got another question. Hawks sells some high performance MAF sensor for $300. Is something like that even worth that much money? Will there be a noticable performance increase whatsoever?
Old Jun 23, 2011 | 02:26 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Have you tried cleaning it yet? They make MAF sensor cleaner. I know in the later GM cars the 2 heated wires sometimes get some dirt on them and that causes an issue. Anymore with MAF sensors I just buy them from the parts store with lifetime warranty if I can find it.
Old Jun 23, 2011 | 02:40 AM
Car: 89 GTA
Engine: 5.7 TPI L98
I have not tried cleaning it yet. I'll have to give that a shot. I was told you just spray it with compresses air because you're not suppossed to touch it. Is that incorrect?
Old Jun 23, 2011 | 04:17 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
local auto part stores should sell an aerosol mass air flow cleaner, around 4-6$
Old Jun 24, 2011 | 12:38 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Thanks! I'll be sure to try it.
Old Jun 30, 2011 | 02:59 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Cleaned the MAF. Still giving me trouble starting, just not as often. Time to buy a new sensor...
Old Jul 1, 2011 | 08:08 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
On a scan tool, MAF should read about 5.5-6 grams per second at idle. Look for MAF to be low and Block Learn to be high.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
