Car wont start
Old Jun 18, 2011 | 10:35 AM
bigk24's Avatar
Car: 1988 camaro iroc z
Engine: 350 tpi
Car wont start
yeah i my car didn't start so i put in a new starter yesturday and it work started turned on and off on and off like 3 or 4 times then this morning my brother used it to drop off my step dad turned off the car and 5 minutes trying to started it nothing happen no crank click or nothing what can be wrong
Old Jun 18, 2011 | 11:01 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Re: Car wont start
Have your checked your positive 12v cable that goes from your battery to your starter
I had a few encounter like your and it was that wire that wasnt hooker up tight
Old Jun 18, 2011 | 11:46 AM
87rattler's Avatar
Car: 87 Iroc-Z28
Re: Car wont start
Does your car have headers, if so your starter is maybe getting HEAT SOAKED. i have a problem when i drive for 15 + minutues, shut it off, and can't start it for about 5 minutes. If i drive for a couple of minutes it's fine. Seems like i have a dead battery, fuel pump primes, lights work, just no crank. wait a bit and she fires right up. So what i am going to do is get an LT1 starter (smaller and better in high heat) and thermal wrap it. My headers get extremely HOT and the starter is right beside them. Could also be your Battery cable getting to hot. Do a search of "HEAT SOAK STARTER" and go from there.
Old Jun 18, 2011 | 03:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Car wont start
Not sure why everyone runs out and buys a starter without diagnosing the problem first - starters rarely go bad anymore (not like the 1970's) - that's why there aren't local starter/alternator shops anymore these days.
Diagnose the wiring ... http://www.austinthirdgen.org/index.php?pid=38
Old Jun 18, 2011 | 04:02 PM
87rattler's Avatar
Car: 87 Iroc-Z28
Re: Car wont start
I had replaced a starter on another '87 i owned, at a fairly low mileage. This starter, starts the car everytime it is cool. But if it has been ran for awhile (city driving) it will not start, for a few minutes. May be it's not heat soaked but a little bit of insulation is a cheap and easy way of helping to diagnose the problem. I have searched and read about this, since the problem happened to me, and alot of people were pulling their hair out diagnosing the problem (fuel pump, filter, Coolant temp sens etc.) and then people were saying that sheilding the heat from their starter or getting a mini starter solved the problem permanently.
Old Jun 18, 2011 | 07:33 PM
bigk24's Avatar
Engine: 350 tpi
Re: Car wont start
i tried starting the car again and still nothing its like not having a battery in there at all iv already checked the fuse box so im guessing its a wire from the batter that goes to the starter
Old Jun 21, 2011 | 11:02 PM
jimidude87's Avatar
Re: Car wont start
So my car has been doing the same thing and i saw on the website for advance auto they sell heat shields. They have 2 different kinds, one for the whole starter and one for the starter solenoid. Is the problem when the starter gets hot or just the solenoid? Thanks for any help
Old Jun 23, 2011 | 01:58 PM
bigk24's Avatar
Engine: 350 tpi
Re: Car wont start
so i check the wires there all good still hasnt started at all i think its the ignition switch
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
