whats the hell wrong?
Old Jun 29, 2011 | 06:38 PM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
really need some help guys pulling my hair out on this one
1st of all just done a bottom end rebuild all back together and now this
(from the 1st time on fire up) car runs but very poorly like its on 6 cylinders, had 2 sets of plugs in one old set and new set, the ht lead have all got a spark, injectors have all got a pules, good fuel psi, i pulled the front end of the make sure the timing is right, set the dizzy up again and again.
running out of ideas must of cheeked every thing 3,4,5.
plain for tomorrow is another set of plugs and to pule the fuel rail of and see if there fuel in all out
any ideas would be great really any ideas!!!!!!!!!
thanks
Old Jun 29, 2011 | 06:43 PM
Guest
Guest
Posts: n/a
Re: whats the hell wrong?
If you're sure it's missing, the best way to find which cylinders is to run it for a minute, then feel each header tube, right near the head. Be careful you don't get burnt. But whichever cylinders aren't firing won't get hot.
How does it sound? If you over-tightened some rocker nuts, then you may have some valves not closing. If so, then no power from those cylinders.
Old Jun 29, 2011 | 06:50 PM
Swap the wires on the dist cap that you think are 5 & 7.
If that's not it, back all the rockers off by ½ turn.
Old Jun 29, 2011 | 07:12 PM
Guest
Guest
Posts: n/a
If those 2 were swapped, then it would be backfiring.
Old Jun 29, 2011 | 07:21 PM
Car: 89 gta
thanks guys. some really good ideas to try out
i am getting a lot of back fire.
Old Jun 29, 2011 | 07:29 PM
See my signature for some help with logic.
Old Jun 29, 2011 | 07:33 PM
Guest
Guest
Posts: n/a
That wasn't in your original post. But since you're getting backfiring, then Sofa is probably on the right track. You may have some wires swapped. If not, then it's back to the rocker nuts.
Old Jun 29, 2011 | 07:55 PM
Car: 89 gta
i have done the valve nuts for the 2nd time but a 3rd time wont hurt if the wire cross over dont work
Old Jun 30, 2011 | 11:25 AM
Car: 89 gta
right done a little more digging.
its 100% not to do with fuel. had the injectors on the fuel rail out of the car tested them all, all fine. so can cross that of.
the valve covers are of but dint have time to play with them befor we had our english summer i,e rain. so will have a look at them tomorrow.
played around with 7 and 5 on the dizzy cap with no luck.
any more ideas????
Old Jun 30, 2011 | 02:47 PM
Guest
Guest
Posts: n/a
It may not be 5 and 7, it may be any 2 wires. If one plug is firing 90 crank degrees to soon, you get a backfire.
Alternately, if one of the intake valves isn't fully closing, you get a backfire.
Old Jun 30, 2011 | 03:13 PM
Car: 89 gta
i think its more likey to be the valves. iv done the wires some many times, unless the gta has a funny firing order from any other small block chevy?
how much turn do you guys put on your valves the book says 1 full turn but iv always know it as 3/4 of a turn?????
Old Jun 30, 2011 | 03:24 PM
Guest
Guest
Posts: n/a
I just go 90 degrees.
Old Jun 30, 2011 | 03:35 PM
Car: 89 gta
really as little as that?
Old Jun 30, 2011 | 06:38 PM
Guest
Guest
Posts: n/a
It's supposed to be a performance setting. It has always worked fine for me.
Old Jun 30, 2011 | 07:10 PM
Car: 89 gta
hummm been haveing a hunt on the net for how much of a turn and iv seen from 1/4 to a full turn and a 1/4 lol
if 1/4 turn works for you then ill give it a go
Old Jul 1, 2011 | 06:31 PM
Fred meredith's Avatar
Car: 91 Z28
Engine: 350TPI
Transmission: 700R IThink
Axle/Gears: 323
Spin the push rod with ur fingers until u feel resistance while tightening and that should be sufficient.
Old Jul 1, 2011 | 07:42 PM
Car: 89 gta
today was a good day!!!! put the fuel rail and intake tubes back on after cleaning them up.
re did the valves this time only 1/4 f a turn and wow of she wents fired up with no probs and sounds sweet as.
crazy iv always done 3/4 of a turn and the book says 12 full turn. a week of **** to get there in the end but so happy.
thank you so much for all your help guys
bad
Old Jul 1, 2011 | 07:57 PM
Guest
Guest
Posts: n/a
No, that's not when you stop, that's when you give it a final 90 degrees. Without that last 90 degrees, it'll end up too loose.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
aaron7
Sep 30, 2015 09:15 AM
