Acceleration is crappy and RPM needle jumping?
I have a 1989 Firebird formula 350 when it first starts up it seems fine but after a few miles it lacks power and if I floor it the RPM needle skipps and jumps and somtimes the passing gear wont kick in. Also when I slowly accelerate it gets shakey and boggy. Please whats wrong and is it one thing or many?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Acceleration is crappy and RPM needle jumping?
Sounds like an ignition issue. Maybe a bad coil or a failing ignition module. The tach jumping is from the ignition intermittently cutting out under acceleration.
Engine: 4++,350 & 305 CIs
Your plug wires are bad. sounds like some are burned thru and shorting to ground.
