Weird delay when accelerating
Old Jul 9, 2011 | 03:05 PM
Sergdog's Avatar
Recently my '88 Iroc-z started having this weird delay between the time i press on the accelerator and the time the car actually moves. When i step on the gas the engine seems to stall and the car takes a couple of seconds to move foreward. It also doesnt just move, it jerks forward. I have no idea what it could be. HELP PLEASE! Thanks.
Old Jul 9, 2011 | 04:38 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Weird delay when accelerating
Do you have any trouble codes via lit SES light? You can have slight trouble with sensors and not initiate the ECM to trigger a TC (trouble code). I had a Hypertech PROM and it was THE BOMB. Throttle response was on demand. Tires would spin as soon as I mashed the peddle. But it went bad and I then got a 1987 IROC-Z PROM BIN file burned into a EPROM. THe fuel and spark tables where a bit modified but throttle response is slightly delayed too. So I would begin with the Throttle Position Sensor. Then the Mass Air Flow Sensor. But before you go and spend a ton of money, do a TPI tune up as well as basic tune up if the problem persists.
http://www.highperformancepontiac.co...gta/index.html
http://mpikas.blogspot.com/2008/08/t...june-2000.html
-Spark Plugs
-Ignition Wires
-Distributor Cap and Rotor
-Air Filters
-Fuel Filters
-PCV valve
-Oil Change and new filter
Old Jul 9, 2011 | 05:23 PM
John Galt's Avatar
Car: 1989 Iroc Z-28 5.7 TPI
Engine: 5.7 TPI
I had a similar problem, and I was having a hard time figuring it out, I ended up spending about $20 getting a usb to serial connector and a serial cable at compUSA which I bastardized into a aldl cable with a resistor. Downloaded WinALDL to my laptop and life has been a lot easier. I saw that the TPS was registering only a third of whatever I was doing (10% throttle read as 3%, WOT read as 33%, etc..) and after replacing the TPS with a new one and getting the same readings, I replaced the ECM for $79 at Autozone. Now I lay rubber down instantly when I hit the throttle. Who knows if this is your problem, but I guess the moral is that the cable and the program on the laptop makes life a lot easier.
Old Jul 9, 2011 | 05:34 PM
So you where able to datalog your ECM? I need to know exactly what u did and how you rigged the cables. I'm a computer tech and I know how to mess with data cables. But I don't know what I need to do what u did. So not to hijack the thread, can you contact me via email? My email address is Silent_for_life@yahoo.com. Thanks.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Hal87
Sep 26, 2015 09:26 PM
