L98 Build!!! Help if possible
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
I am about to rebuild a l98 shortblock and on top of the rebuild im going to add new forged pistons and rods. I am going to go with Lloyd Elliott LE2 head and cam combo and then im also going with a holley stealth ram. If you guys can help the things above are things that are going on it. Please if you can help or give better advice please do so!!!!
Im going with
Accel 36lb injector
Holley 58mm TB
New oil pump
New oil pan
pro build automatic 700r4
vig 3200 stall
already have headers and 3'' exhaust
i have 3.23 gears
any other things you think i should redo when doing this rebuild i want to just do it once and right. My goal is a low 12 sec car in Las Vegas. Thanks
Im going with
Accel 36lb injector
Holley 58mm TB
New oil pump
New oil pan
vig 3200 stall
i have 3.23 gears
Mongoose462ci
Sep 16, 2015 11:46 PM
