Oil Pan Leaking!!!! Please help!!!
Car: 1986 Iroc-Z :)
Engine: 305 Tpi, cam, headers, super coil
Transmission: 700r-4 with shift kit
Axle/Gears: 3.23 posi
I have a 86 Iroc-z with a 5.0L 305. I have the "dual dipstick" set-up where there are two groves on the pan. (One on eachside). I need a gasket but cat find on any where. Where can I find one? And could the one side not being coverd be the reason im lossing all my oil in mins?
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Oil Pan Leaking!!!! Please help!!!
Try searching what kind of cars came with the duel dipstick for the motor you have and then head to a parts store. The other side being open would deff be the cause of oil lost. Try to plug the hole if you can. If you cant find a gasket now, try RTV that's oil resistant as a temporary solution.
Car: 86 z28,89 iroc
Engine: 350 crate and ls1
Transmission: 700r4/4l60e
Axle/Gears: open diff stock/4th gen posi
its not a stock motor guys...its a gm goodwrench crate replacement engine which is why the pan is like that....
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
