can I replace a/c v-belt with non a/c belt
Stock 86 lg4 with a/c.My a/c has not worked for years and I have no plans to fix.Belt needs to be replaced,can I just replace with a belt for non-a/c car and route around crank and steering pump pulley,or is it a different belt?I see no need to turn the compressor if im not using it.thanks
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: can I replace a/c v-belt with non a/c belt
You should be able to do that. As long as the belt is the correct size and length you should be good to go. My car didnt have the compressor/AC so I'm assuming the previous owner installed a non AC belt.
now that ive thought about it-how would the belt be adjusted/tightened if not around the a/c that has the adjustment slots.The power steering pump doesn't,or does it?
Good question. I never actually looked into that since I haven't changed the belt out.
1992 Trans Am
May 10, 2023 07:19 PM
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
