Heads for 305
Old Sep 6, 2011 | 11:44 AM
rslickster's Avatar
Car: 1986 IROC Z28
Engine: 87 Small Block Roller Motor
Heads for 305
Will ZZ4 Heads fit a 305 TPI 1987? Can the exhaust Crossover be fixed to work with the EGR Valve. What Aluminum Head with small Chamber would you use?
Old Sep 6, 2011 | 05:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
ZZ4 heads would fit. You basically need to use the '86-1/2 aluminum head Vette TPI set-up.
If I was going that route, I'd choose one of these (the difference is the valve lift capability):
http://www.summitracing.com/search/D...s/?Ns=Rank|Asc
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
