high idle on 5.7tpi,need advice
Old Sep 11, 2011 | 07:22 AM
HorsePowerJUNKI's Avatar
Car: 86 trans am gta,and 88 corvette
Engine: TA-355ci tpi,vette 383 tpi
Transmission: 5spd manual,700r4
Axle/Gears: borgwarner 370 posi,vette is stock
high idle on 5.7 tpi ? i have a fresh rebuild tpi 350 new sensors new distributor,new injectors,same ecm and prom,set tps and timing.never touched idle speed screw. still has factory plug in hole.fuel presure 43-45psi,it idles around 1500-1700 rpms i have tried everything to try and bring it down.when i drive it up the street it seams to run ok for a minute or two then it starts to choke out and dies.starts rite back up and same thing.pops a few times before it dies.iac is also new.check engine lite on all the time.and the fuel pump is running all the time.mass air was good before i rebuilt the engine.any input from anyone thats experianced this issue would be appreciated.thank you
Old Sep 11, 2011 | 10:21 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: high idle on 5.7tpi,need advice
Check for vacuum leaks and air leaks around the plenum and runners. You may have put the gaskets on backwards.
db057
Sep 4, 2015 07:57 AM
injdinjn
Aug 28, 2015 12:51 PM
Hello, Michael
Aug 20, 2015 03:19 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
