Random Camaro issues
Old Sep 17, 2011 | 04:26 PM
camarosindahood's Avatar
From: Wisconsin. Currently Southern Milwaukee Area.
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Hey everybody, this thread is gonna be a bunch of assorted issues I have with my car, just checkin to see what people have to say about them. First issue:
when my car warms up, it has a rough idle goin on. The revs will drop in an irregular manner, sometimes to the point of shutting the car off.
any ideas?
Old Sep 17, 2011 | 07:25 PM
bigjcfiredog's Avatar
Car: 91 RS
Engine: Vortec 350 TBI
Re: Random Camaro issues
EGR or TPS or CTS. Depends on lots of variables. CTS is cheap. I uplugged the cts and drove. It rectified the problem, but really was masking the real issue with my EGR. With the CTS disconnected it makes the computer think it is -40*. It will throw a code but run well.... Next reconnect CTS and unhook the vac line from the EGR. If it is still fixed your EGR is the problem, if it remains start with the CTS. Best thing is to really think about what is going on. Mine was surging and bucking but only when warm. Sometimes would die when I let off the gas, but yours could easily be different as mine is a 350 TBI.
Old Sep 18, 2011 | 12:53 AM
affliction1's Avatar
Car: 89 chevy camaro rs
unhooking cts would cause the car to run extreemely rich(car trying to warm its self up.
i say clean iac,tps.to start with
Old Sep 18, 2011 | 03:16 PM
Car: 91 RS
I agree affliction. However, I ment for him to unhook and run for a few miles once it is warm. We did this for only about 20-25 miles. It just showed me part of what is wrong. I hate to just change parts, I probably didn't have to replace my CTS. Just be sure you test before you change parts.
If the no CTS test helps then unhook the vac line from the EGR. I have this experience so just want to see these cars run right and keep them on the road.
Old Sep 18, 2011 | 05:05 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
alright, how do i take the CTS on and off?
Old Sep 18, 2011 | 06:40 PM
Car: 91 RS
Just unplug it. It is on the intake by the thermostat housing on the V-8's. Do this then drive it around, see if it fixes or changes anything. Then plug it back in and remove the vaccuum hose from the egr (assuming you have one) or unplug the solenoid and see if that helps.
This will help narrow the issue down. Let us all know what if anything is different. These things will probably set a code but once you check them they can be erased easily.
Old Sep 18, 2011 | 11:37 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
well, u may have noticed that i do not in fact have a v8 lol
is it in the same place on the v6?
Old Sep 18, 2011 | 11:49 PM
Car: 91 RS
I did notice that you had a 6. That is why I added the part about the 8. I will have to check where it is on the 6 tomorrow. The boy left the Haynes manual in the car. you might be able to find it online.
Old Sep 19, 2011 | 12:07 AM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
hmm, well what im guessing is that im just getting bad compression, because i took it to my mechanic and he blew smoke into the engine and he said there were some leakes. is a rebuild the only way to fix it in that case?
Old Sep 19, 2011 | 07:28 AM
lol dont rebuild a 3.1 first off if anything upgrade to a 3.4,3.8,4.3vortec
youll save sooooo much time and money and be happier in the long run (more power)
Old Sep 19, 2011 | 11:53 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Ya, ya, im not a noob lol. I got a 350 sitting in my truck just waiting for the funds to accumulate in order to rebuild it and throw it in the beast
Im just trying to get the 6 runnin pretty dec until that happens
Old Sep 26, 2011 | 11:37 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
anyways, issue # 2
my front axle makes funny noises when i go ever bumps
go!
Old Sep 27, 2011 | 07:54 AM
torque_is_good's Avatar
anyways, issue # 2
go!
squeaks
clanks
bangs
thuds
go!
Old Sep 27, 2011 | 05:19 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Originally Posted by torque_is_good
squeaks
clanks
bangs
thuds
go!
clanks lol
Old Oct 1, 2011 | 10:09 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
anybody home?
Old Oct 2, 2011 | 12:09 AM
Car: 91 RS
anybody home?
I am home....but I think that might be irrelevent. I think you need to get everything lubed and make sure your struts aren't worn out. Bangs make me think something could be broken.
Old Oct 2, 2011 | 12:35 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
grease all your suspension, with a grease gun. See if that helps. But while you are under there check everything out to see if any of the rubber is cracked, worn out.
Old Oct 2, 2011 | 01:53 AM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
well, there arnt any bangs, and the car rides fine, so i dont think anything is outright broken. the suspention compresses just fine and doesnt make any noice at all. it clanks when the left wheel moves up or down without the other side doing the same
Old Oct 7, 2011 | 08:08 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
next thing:
will a 350 from a 92 silverado bolt on to my 700r4?
Old Oct 12, 2011 | 05:34 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Yes it will
Old Oct 20, 2011 | 02:59 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
cool. now, will a 6 speed from a 4th gen camaro bolt to me 3.1 v6?
Old Oct 20, 2011 | 04:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check the sway bar end links and mount.
Old Oct 20, 2011 | 08:39 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
dont know if the 4th gen v6s came with a 6speed option, but it its bolted to a v-8 no, and a v6 700r4 wont bolt to a v8.
if you swap the v6 for a v8, youll need a v-8 trans.
Old Oct 25, 2011 | 07:06 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
So your saying that a 6 speed from a v8 4th gen wont fit my current v6?
Old Oct 25, 2011 | 07:53 PM
travis401's Avatar
Car: 91 Camaro RS
Thats exactly what im saying. The bolt pattern for the bell housing is completely different between the v6 and v8. It physically wont bolt to your v6.
Old Apr 17, 2012 | 12:10 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Alright, i greased all the fittings under the car. The fitting that is right underneath the brakes on the drivers side would not hold any grease (which is also the side the noise is coming from) so i bought a new fitting and put it on, and now it holds grease just fine. Didnt really help the noise at all. My freind seems to think that I need a new ball joint.
Old May 3, 2013 | 12:04 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
well, now the head gasket is blown and the valve seals are probably shot, so i got bigger fish to fry
Old May 3, 2013 | 12:10 PM
wishoradream's Avatar
Car: 1982 Z28
Engine: 388 SBC
Transmission: TH350 Lockup
I'd dig out a 350 somewhere, craigslist, or a salvage yard, and just go that route with it, sounds like you're gonna be neck deep in that motor longer than it would take you to get a good V8 setup
Old May 3, 2013 | 01:22 PM
Car: 1991 Z28
Engine: 5.7 TPI
Axle/Gears: 4.11
Well, i do have an lt1 on a stand sitting next to the car
problem is that the floors are so shot that the frame is rusted. Wouldnt be worth swaping a new motor in. i just wanna get it running so I can sell it
Frozer!!!
Jan 19, 2024 04:55 PM
Wesly_66
Aug 26, 2015 09:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
