HELP! :)
Old Sep 24, 2011 | 07:15 AM
Teknicktion's Avatar
HELP! :)
i just purchased a 1988 GTA 305 5.0 Tuned port % speed. #4cyl is essentially dead. i did a Tune up with OE parts. I even changed the coil.
The car has a after market ECU in it from Accel. I called Accel and they have no info on it. They said they havent sold that ecu since 1998. I put a noid light on #4 injector and it is pulsing. I have spark going to the plug also. At this point i was sure it was a valve. I did a compression test and have 150. according to All Data thats good. Can it still be that accel ecu even thogh i have pulse? Im at my wits end. Any help would be highly appreciated.
-Nick
Old Sep 26, 2011 | 11:48 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: HELP! :)
It may be a bad injector. I had one that was stuck open once. Maybe yours is stuck closed or partially closed? You can use an ohm gauge and ohm all the injectors. This will prove if they're electrically ok. The readings should be close to each other. However, I don't know a way to test them mechanically without pulling them and sending them off or replacing them.
Hope this helps.
Old Sep 26, 2011 | 04:52 PM
Re: HELP! :)
Hope this helps.
I will give it a try. Thank you you for your advice.
Old Oct 23, 2011 | 08:38 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: HELP! :)
Was it the injector?
Old Oct 23, 2011 | 03:26 PM
Re: HELP! :)
The ECU was no good. The new/used ecu fixed it. Thank you all for our help.
