What is this part (84 L69 w/bad pic)
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Searched hi and low and I cannot find a name or specific function of this exhaust part.
It's from an 84 Camaro with an L69 and 5-speed manual, engine Vin G. It resides in the exhaust just downstream of the passenger exhaust manifold and my best guess is it is some sort of vacuum actuated butterfly valve.
Even just a name would be enormously helpful. It is hard to search for info when you don't know the name of the part. If you know how/why it works and willing to share that info, that would be even better.
Pic is there, but not very good. Hard to take a pic of a part that is elbow-deep in the engine bay.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: What is this part (84 L69 w/bad pic)
Its the early fuel evaporation vacuum servo/valve. Preheats the intake with exhaust gasses when its cold.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Also known as the EFE valve (a search will provide a ton of info). If it's still functioning, I'd be surprised--as it doesn't appear to have a vacuum line to it. Here's a diagram that may be helpful:
https://www.thirdgen.org/forums/atta...se-routing.jpg
The TVS by the way is the thermal vacuum switch.
JamesC
JamesC
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
It was not used on the FI cars and they had a donut spacer in its place. The spacer is a good option if/when removing this infernal device.
Awesome. Thanks guys.
Trying to figure out my lack of ability to idle when cold (completely custom megasquirt fuel delivery system). That vacuum diagram may actually hold the clue. Too bad it wasn't under my hood where I assume it should be
LT1Formula
20
Nov 14, 2015 12:02 AM
