need help wont crank
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
I have a 89 with 2.8 the car will not crank not one bit of noise the battery is good and alternator is new what is the problem I drove it to the store then when I tried to start it the lights came on then nothing
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: need help wont crank
does it turn over at all? could be a blown fusible link.
Car: 1987 Trans Am
Engine: LQ9/L92
check all the connections at the starter and try giving the starter solenoid a couple of love taps, see if there's any change. may have a bad starter, but you'll need to do a bit more testing to see where the weak link is
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Move the batt connections also.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Is there a light on your dash that stays lit, and reads "Security"?
Run the positive cable from the battery to the starter. See if there is any bare spots or "swelled" areas. A swelled area would indicate corrosion which could be your problem too. If you find that, a new cable is in order.
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
Make sure your battery cables are nice and tight, especially the negative. if it makes no contact(sound) could be your ignition module.
skinny z
Oct 5, 2015 06:23 PM
