Overheat, Runs Rough
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Went away on a trip didnt check fluid levels when i got back. Realized my car was overheating pegged at 250 and had my reservoir overflow. Filled it back up after it cooled down car starts fine no white/blue smoke coming out of exhaust and i dont see any cloudiness in the oil so I'm thinking the head gasket is ok. I am getting rough idle and loss of power very similiar to a missfire. I can drive it ok but its a little rough again like a miss fire. Could i have messed up my copper plugs or some sensor like the IAC etc...? Any help would be great thanks.
Car: 82 Firebird/ 79 Camaro Berlinetta
Engine: 151 Pontiac Iron Duke TBI/ 305 SBC
Transmission: THM200/ THM200r4
Axle/Gears: 2.93/ 2.41
Re: Overheat, Runs Rough
From my experience from overheating and running a car hot you can burn out your spark plugs to the point they need to be replaced. Thats just what it sounds like to me.
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Figured out. Plugs were fine looks like overheat coincided with one of my ignition cables coming loose from the plug. Put it back on and car is fine.
