hmm...what to do?
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
hmm...what to do?
So I have about $1,500 to throw at the car. Im basically looking for input at the most bang for my buck! the car is a 91 350 TPI
HERES WHAT I WAS THINKING: Set of Vortecs, Comp cam Kit, Msd Ignition Box, and Some SLP runners(Cheap pair local already Siamesed), Flowmaster exhaust
Currently the vehicle already has SLP Headers and an exhaust that im not to fond of.
I just recently Picked up this 91 GTA and im looking to get a Pretty quick Daily out of it. any input as to what YOU would do is greatly appreciated? Am I on the right track? anything you would change or anything ive left out? Realistically what numbers would I be looking at? Input is Greatly appreciated!!!! Thanks Guys! Trae
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: hmm...what to do?
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
We don't know if you have done anything to the suspension yet any sub frame connectors or wonder bar?
Axle/Gears: 3:42
Realistically, u r looking at 305+ hp with exhaust,headers, vortec heads,lower intake manifold base, slightly larger cam (to work with the ecm) Still going to need a custom tune(chip)
Axle/Gears: 3:42
that will put u in the 13's, u will touch the 12's with a 2500 stall and sticky tires
Grrr wasnt aware I needed a dif intake although with said manifold the SLP runners exhaust and vortecs would the gain be worth it? Also on the suspension....negative nothing as of yet...tires are Michelin pilot sport a s pluses...traction is not an issue..why no msd box?
Axle/Gears: 3:42
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You don't need the ignition box. The lower intake base you need to use with the vortecs and TPI is pretty expensive, especially considering that the gains you'd expect from the vortecs will be choked by TPI.
I vote for subframe connectors and good shocks/struts along with better exhaust (you already have headers?).
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Axle/Gears: 3:42
i vote for a chip tune. You wanna be nice and zippy around town,like driving a 5 speed turbo car,but then when you go WOT want it to richen up and feel strong. From what i hear our cars run too rich at part throttle and too lean at WOT. U want the opposite.Wait til u do exhaust first
Yes it came with SLP headers not sure what exhaust but IMO it doesn't sound to good. the struts have been changed up front I gave the front end a once over there Monroe's I do want to put the eibach lowering springs on it, but What would subframe connectors do? The vortecs would still be restricted with the lower intake and SLP runner?
Axle/Gears: 3:42
so would it be better to keep the stock heads and have them ported and all that jazz(new rockers, springs etc...)? seeing as the vortecs dont flow that much better ? and if i do so i know theres not much meat to the stock tpi runners so I do want to throw those slps on there..or does it just open more possibilities to go with the base, vortecs,runners...
Axle/Gears: 3:42
hmm I guess Exhaust,chip and suspension it is. I have a shop in mind thats local for the exhaust. I was thinking Flowmaster. and would this shope be able to weld in the subframe connectors? Ill throw in the wonderbar and strut tower brace. but will I need an alignment after?
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
This is a great thread, has alot of useful info. Simple things, and theres some things that are even free to do:
https://www.thirdgen.org/tpimod1
Axle/Gears: 3:42
Car: 1984 Camaro sport coupe
Engine: 5.0(H/O) 305 carb'd
Transmission: TCI St. Fitr stge 2 700r4 man.valve
Axle/Gears: stock gears, Limited Slip
to make a 383 stroker: take out stock crank and install a 400 crank( 250bucks) add a decent cam n lifter kit( 300bucks), upgrade your intake mani to your liking, posi (450bucks) 3.73 gears if its automatic or 4.11 gears if its 5spd (170bucks)...thats wut i would do, oh and uh upgrade ur injectors and maybe FPR and fuel pump Junior Member
yeah sub frame connectors will keep ur frame from twisting on take offs. bent frames = junkyard car. you dont want that
Yeah I read that article. But I thought with a 383 I had to also go with a bigger bore not just a bigger crank? If these mods won't require subframes at about what range would I need them?
if u need drag bars to stop ur ride from flippin up...then i would invest in some sub frame connectors. or if u get a blower or super charger or NOS.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
You will need to get the block bored out .030 for a 383, as well as the rest of the machinework to ensure it's all prepped right, and balanced.
Engine: 4++,350 & 305 CIs
I would start with a trans rebuild and a great TQ converter.
Its above your budget but its the best place to start.
The sub frame connectors are going to help no matter what your power levels. The difference in stiffness is noticeable over bumps, corners, driveways, etc. along with getting rid of most of the creaks and groans that your stereo probably drowns out.
Axle/Gears: 3:42
I thought shocks have to do with that
Axle/Gears: 3:42
When ever i hit a even a small manhole cover in the road it feels like i have just gone off a curb! LOL
sounds like you need some time and money invested into your suspension. front/rear shocks n springs...maybe a steering rebuild kit from Hotchkis and some boots n bushings. just a suggestion though.
Ahhhh! Gotcha I was wondering why the GTA creaked. My 92 didn't used to make a peep. Granted the ws6 suspension is a leap skip and a hop more sound. Rides and Handles better than most new cars I've been in. But everything I've read has kinda pushed me to go with the subframe connectors wonder bar and strut bar. Also got the exhaust priced out today at a local shop.
