Need thoughts on engine
Man, I feel like such an amatuer on here. Attempting my first build for 1/8th mile all on a budget. here is what I have so far.
86 Z28
Engine - 1978 350 - stock block, heads and crank
Cam - 234/234 480/480
Valve springs matched for cam
Aluminum flat top pistons 10:1
High rise intake with 650 Holley double pumper
Hooker comp headers
I know I have a long way to go but right now motor runs good with very nice throttle response. Any low budget ideas would be great!!
86 Z28
Hooker comp headers
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Need thoughts on engine
86 Z28
Hooker comp headers
86 Z28
Hooker comp headers
Do you have dual exhaust or 3" single cat-back? Do you have headers? A good exhaust upgrade from stock manifolds will free up anywhere from 15-30hp depending on your car.
If the heads are stock to 1978, get rid of them and go after market. You can probably pick up a good used set on Ebay or local craigs list. Also check the "parts for sale" boards here on this site. For new..,World, Trick Flow or AFR come to mind but that's $1200 for a set. That cam is too big for Vortec's which top at .475, though I'm sure you could find a shop that can mill them for you.
Hey Ozz, thanks for the reply! The car is strictly 1/8th mile, it has hooker competition headers (1 5/8 primary with 3 inch collectors. I have 2 1/2 reducers and have dual exhaust running to about back of doors with no mufflers. Budget = what I can convince the wife to give me = not much. lol... I had a guy tell me to get vortecs, should i look at getting something ported or milled, $1200 for heads isn't in the budget. This car is strictly for fun on Saturdays at the track
Car: 1984 Trans Am
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
What gears do you have currently? That, and the best bang for your buck is in a set of cylinder heads. Your stock heads are massively holding you back with that cam you've got in the motor right now assuming they're plain jane stock. If I were you - I'd try to find a nice set of used DART/AFR/BRODIX/TRICKFLOW heads.. I'd recommend the vortecs also, provided you get a good deal on the intake to match them; but at that point you could've used that extra to go towards better heads.. so, yeah.
Outside of that? Suspension. I know you say budget, but there's just some things you HAVE to do if you really want to start moving down the line quick.
Car: 1984 Trans Am
New Heads and gears. If $1200 for new isn't in the budget, check out Ebay or our classifieds here, you may find something good. Vortec's just happen to be the best Small block head chevy ever made, not counting some of the newer LS model heads...so thats something to think about. A good set of those with a Vortec Intake ($250ish from Edelbrock) wouldn't set you back too far. Also, for 1/8 mile only? I'd go with 4.11 or 4.88 gears. If you're running 1/4 mile, I would probably stick to 3.73's otherwise you're spinning your RPM's into the stratosphere.
Now, some things to consider. Sub Frame connectors...I would say these are a must on 3rd Gen cars, T-top or not. Polyurethane bushings, again, highly recommended. is the car lowered? Rear lower control arm relocation brackets. Adjustable torque arm, adjustable panhard rod. This will all help keep the car planted and going down the track.
Next, running at a track with slicks or DOT Drag radials on a 10-bolt rear is playing with fire. Once you cross the 375-400ft-lb mark, a 10-bolt is living on borrowed time. One good hook up on slicks could cause a complete disintigration. A couple things you can do is upgrade from your 26-Spline axles to the later model 28 spline axles (89-92 years), then get a brace to help hold it, weld the axles to the carrier etc. But that's expensive. So you'll want to start looking at a 12-bolt or 9". Thos run $2500 new from Strange or Moser but will be built for your car. Oh, and then the tranny will need a rebuilt to handle the extra power, then once that's done, the motor will need to go up to be able to max out your new rear and tranny.. See what you have to look forward to? It never ends!! hahaha
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Budget, get a set of vortec heads, clean them up/mill them down to bump compression, put in good gas, cam it up abit more, lots of converter, lots of gear and go racing
750cfm carb double pumper and a ported dual plane or even single plane but I think it will run abit better with a good dual plane.
Problem is loads of gear in a 10 bolt makes for a tiny pinion gear and it just may not like abuse for a long time and start to break teeth.
Hey Ozz, yea we are thinking this fall in the off season of doing a 383 stroker, we already have the block and rotaing assembly. My current motor is in the car, afew more small things to do then we have a stretch of road we are gonna go out on and see how it does.
Hi Delta, thanks for the post! right now the car has the stock 2.73 gears, I looked at getting a set of 3.73's and I also have purchased a spool for it. I was thinking of Vortec heads, is it possible to have the stock heads reworked enough to handle where I am headed or better to just look for diff heads.
Yea Ozz I have a feeling the play toy will only get more serious. I am actually thinking once this is done to run respectable I will probably start looking for a full frame and get away from the F body.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Car: 89 Iroc-z
Transmission: TH400
Stock vortec heads with valve guides machined down to handle more lift and screw in rocker studs will get you a strong performing motor if/when you are ready for it. 400+ hp is possible and thats a stout street motor
Car: 1984 Camaro sport coupe
Engine: 5.0(H/O) 305 carb'd
Transmission: TCI St. Fitr stge 2 700r4 man.valve
Axle/Gears: stock gears, Limited Slip
i have read up on several tech forums and consulted with couple shops. be careful on the gears you choose.
recommended gears are as follows: for 5spd manual suggested 4.11 gears, for automatics 3.73's or 4.10's.
if you want track performance only and arent planning on driving down city roads and high ways i wouldnt go any higher than 4.11's or 4.10's due to gas mileage dwindling fast. plus you'll be driving down the road doin 30mph but sounding like ur going 70mph. oh and uh make sure you recalibrate ur speedo...just my
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
If it was only an 1/8 mile car I would get a set of 4.11 gears for it.
What kind of tranny are you running?
As far as heads. I am not sure if these are any good but might be worth checking out. http://www.ebay.com/itm/SMALL-BLOCK-...item4cf76cd187
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
They are also half the price of their competitors. Sure they wouldnt be as good as a set of Brodix heads but I bet they would be better than a set of vortecs for about the same money after you take the vortecs to the machine shop and hope you dont have a cracked head.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
I'd go with a set of Vortecs over Procomp heads. The chances of a cracked head aren't massive, and even if that's the case.. you're out MAYBE $150 at the most.
To be fair - I've never owned a set of Procomps.. I've WANTED to, but I have seen wayyyy too many horror stories to just blow my money away like that. If I were you, I'd buy them bare and have them assembled with good components because the standard stuff they come with is trash. Then MAYBE I could see buying a set as a viable option.
Car: 89 Iroc-z
Transmission: TH400
If you want a decent quality budget head, go with Dart SHP heads which are based on old pro 1's. They have an ok port design that doesnt really flow that much compared to the new design Pro 1's, but they are budget and can support ok hp levels
Get the 200cc version if you use them.
Other option is the JEG's brand heads...same as pro-filer castings but Jeg's name and lower price...actually about same as pro-filer in price. Pro-filer has a good port design and can make big power. Few bucks more you can have them cleaned up with some minor hand porting and custom valvetrain matched to your setup by Chad Speier.
Keep in mind match the springs to the cam you use. If you have aggressive hyd roller setups, most stock out the box springs are not enough to handle them. Look for 150lbs seat pressure and 360-400 open pressure at max lift. thats a good starting point for an agressive hyd roller. Other milder stuff can get away with 130-140lbs seat pressure, 350 open or so.
Get the 200cc version if you use them.Other option is the JEG's brand heads...same as pro-filer castings but Jeg's name and lower price...actually about same as pro-filer in price. Pro-filer has a good port design and can make big power. Few bucks more you can have them cleaned up with some minor hand porting and custom valvetrain matched to your setup by Chad Speier.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
CarGuyDennis
137
Dec 6, 2016 11:02 PM
