Odd launch behavior
Old Mar 10, 2012 | 03:05 PM
johnnymotz27's Avatar
Car: '89 L98 G92 Iroc /'11 GS Vett
Engine: L98/LS3
Transmission: 700R4/M6
Axle/Gears: 3.27 B.W./3.42
Odd launch behavior
Hello all, just broke out the iroc from winter storage and did an oil change and got a fresh tank of gas. Car is running great except from a launch. When i come to a complete stope and launch the car i get some minor wheel spin and then when it hooks up and goes it immediately shifts into second gear. It is not reving up through the rpms before shifting into 2nd.
Car is a 1989 Iroc with L98. Rear has been swapped to a G92 optioned rear.
Thoughts?
Old Mar 10, 2012 | 05:21 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: Odd launch behavior
I guess it didnt do this before?
What if you ez into it will it hold first?
Old Mar 10, 2012 | 06:27 PM
Engine: L98/LS3
I have never had this happen before. If I ease into it and then give it full throttle it will shift very close to the yellow/red line.
Mark_ZZ3
May 24, 2018 01:02 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
