Question
Old May 12, 2012 | 10:59 AM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Question
I disconected the timing wire on my 88 tbi... Set the timing to a happy -6 then turned off the car and reconected the wire... Was i suposed to leave it at 0.. Then plug it and advanced it to -6?
Old May 12, 2012 | 11:36 AM
pvr007's Avatar
Engine: 305 TBI
Re: Question
bump
Old May 12, 2012 | 11:39 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Question
you did it correctly by setting the base timing with EST
in bypass(wire disconnected)if you had set the timing
with wire connected,base timing would be retarded.
Old May 12, 2012 | 11:49 AM
pvr007's Avatar
Engine: 305 TBI
Re: Question
thanks you are a life saver
Old May 12, 2012 | 07:49 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Question
why dose it say -6*you should bump the timing up = +6*
Actually mine runs best a +4* with mid grade fuel.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
