Help me build a 350
Old May 18, 2012 | 11:20 AM
VandykeT/A's Avatar
Help me build a 350
The motor is going in my 80 T/A. I've got a 3970010 block with 333882 heads on it. From looking at it its never been rebuilt or the oil changed in it. It ran good just puffed smoke at WOT. I want a good streetable motor that will have some good kick to it. I'd like to at least have a 13 second car in the end. What will I need to do to the 350 to get there? I'll be running a 350 Turbo and 3.42s
Old May 18, 2012 | 03:22 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Help me build a 350
Those 882's need to go in the trash. Get a set of vortec heads and upgrade the springs.
http://www.lunatipower.com/Product.aspx?id=1966&gid=284
Get a mild cam like that one... and get yourself a decent converter to match it (DON'T GO CHEAP ON A CONVERTER!). Match it with an Edelbrock dual plane for the Vortec heads. And yes, that is a solid flat tappet cam. If you want a hydraulic flat I've still got mine brand new I can sell to you.. it's a XE274 which will also work fine for your application. I went to a solid flat from Bullet Cams so I no longer need it.
The heads are the most important part, though. Those 882's are terrible. Worst $100 doorstop I ever bought.
Old May 18, 2012 | 03:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Best way to go about getting the heads: http://sdparts.com/details/scoggin-d...ter/sd8060raag
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
