Gathering a list of things that could cause rough idle
Old Jul 8, 2012 | 07:58 PM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
My car , in park and at low speeds, like to jump at idle from 500 to 800 nonstop. Sometimes its erratic sometimes its more controlled...
So far I can think of
-EGR Valve
-Vacumm Leak
-Idle Air Control
and wish to gather a list of more things I need to check. I have a 85 camaro with a 87 camaro 350 tpi.
Old Jul 8, 2012 | 08:42 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Gathering a list of things that could cause rough idle
Cracked distributor cap. Crossed plug wires. Timing. Burnt plug wires.
Aluminum // brass mix from plug wires to plug, plug wires to distributor.
Just a few things to check that doesn't take but a few minutes.
My " other " car had a vacuum leak & would go from 900 to 1800 RPM, so that
is a " could be " issue. Our Camaro doesn't have any of the ECM, IAC, etc. Sorry I don't have a solid lead.
Good luck
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Bob88GTA
Aug 18, 2015 03:31 PM
