2nd series or 3rd series rearend?
Old Aug 27, 2012 | 12:51 AM
vitolizer324's Avatar
How can ya tell what rearend you got? I need to know, I'm buying a set of gears for my rearend out of a 87 camaro RS. Thanks
Old Aug 27, 2012 | 01:03 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 2nd series or 3rd series rearend?
Check your SPID sticker or pull the cover.
Old Aug 27, 2012 | 08:40 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Pull the cover and look on the edge of the gear, should be stamped with the gear size.
Old Aug 27, 2012 | 11:45 AM
Ok cool, Thanks. Series 2 is 3:23 or higher correct? I'm looking at buying 4:56 gears..
Old Aug 27, 2012 | 11:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No. The following 10-Bolt FAQ (in the Transmission and Drivetrain forum) will answer many of your questions.
BTW, welcome to TGO. Best of luck with your project.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Aug 27, 2012 | 02:15 PM
red rock's Avatar
Car: 1987 iroc
That's a great site with alot of info. Count the cover bolts, could be a 9 bolt or 10 bolt.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
djmarch
Oct 2, 2015 10:41 PM
Dragonsys
Sep 25, 2015 03:51 PM
tuningnewb
Sep 23, 2015 07:06 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
