Cam timing help please!
Car: 1984 firebird
Engine: yanmar 4TN82
Transmission: NV1500
Axle/Gears: 3.30-ish... not sure
Hey everyone, I've got a 305 that I built about 2000 miles ago that I'm trying to figure out what I think is a cam timing problem
it's standard bore 9.5:1 compression 187 casting heads TBI
(soon to be crossfire as soon as I get this figured out)
I put the comp cams 12-304-4 which is supposed to be a really mild lift super low end torque cam that is very computer compatible.
the problem is that it tries to lope a bit at idle and the computer hates that and goes crazy (did some prom burning and made it a lot better but not perfect)
the thing I'm noticing is that it has no power until it revs to like 3500 and up
which is totally not what this cam is supposed to be for.
I measured it with a degree wheel and got even more confused.
intake centerline measured 109* it's supposed to be 107*
intake .006" open measured 10* it's supposed to be 16*
yes, I measured before my lifters leaked down so that isn't the problem
I measured it exactly how comp cams says to.
why would these two specs be different amounts off?
it is 2* retarded on centerline and 6* retarded on opening
would that be enough to cause my engine to run completely different?
how much should I advance my cam?
junkcltr
Aug 2, 2019 11:12 PM
