will a lt1 cam work in a pre 88 350?
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
i have an lt1 cam i want to replace my stock cam with but i have a pre 88 block will it work what else will i need?
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: will a lt1 cam work in a pre 88 350?
You need to have a roller block, I believe roller started in 87' get some casting numbers off your block first. Also you need to have the little pin on the front of the Lt1 cam ground down first ,for it to work on a tpi motor.
You can do it, with 5 things:
Just so you can re-use some random stock cam. :barf:
Meaning, this doesn't meet the criteria for being worthwhile (those criteria being, better function and/or less money).
Just because a thing can be done, doesn't automatically make it "A Good Idea".
- A set of "retrofit" roller lifters
- A factory-roller timing set
- A spacer to take up the space the retainer plate would have taken up if you could use one, which you can make by simply grinding the "ears" off of a retainer plate
- A cam button, which you will find there aren't any for that setup (the sprocket bolts for the timing set you have to use are MUCH closer together than the old pattern, and the button won't go down in between them) but you can make one if you get a nylon one and whittle it down
- A timing cover stiff enough to hold the cam still
Axle/Gears: 3:42
yeah truck vortec short block and you'll have a 300hp motor. Even with a cam and bolt ons on tpi ,you wouldn't acheive 300hp
1992 Trans Am
Aug 8, 2015 08:16 PM
