A/C questions?
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
A/C questions?
No idea if this is the right place to post this or not but here goes. I have all new a/c componets for my 89 iroc (compressor, condensor, evo canister). My questions are:
1) How are is it to change these parts (the system has already been drained as I had it tested for leaks, of which there were many, and they sucked all the freeon back out)?
2) If I install them my self is it going to hurt them if I drive the car to the shop to have the system charged as long as I don't turn the ac on?
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: A/C questions?
Also remove the orifice tube and flush the evaporator and install a new orifice tube. Add some pag oil to the condenser and evap before assembly, maybe 1-2 fl oz. Make sure the compressor has oil. It will be fine as long as it stays sealed.
Car: 89 IROCZ
Re: A/C questions?
I have a new evaporator (silver canister on the heater box correct?) but which one is the orifice tube?
Re: A/C questions?
That's the accumulator. The orifice is inside the line from the condenser to the evaporator.
Car: 89 IROCZ
Re: A/C questions?
Mine has already previoulsy been change over to the new 134 freeon if that makes a difference.
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
