Need help please
Old Feb 16, 2013 | 10:33 PM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Need help please
Would anyone happen to know the hood clearance from the intake manifold on the LO3 V8 in the 92 Camaro RS? I want to put an open element air filter on my engine and i dont know if the one i want will be clear of the hood.
Old Feb 17, 2013 | 08:24 AM
ex-x-fire's Avatar
Re: Need help please
You should be able to fit a 14x3 air cleaner w/ a flat base. You'll need to remove the spacer ring, thats a restriction anyways, make sure the base is clear of the linkage.
Do a search, hopefully you'll find some part numbers.
Old Feb 17, 2013 | 01:59 PM
Jake_92RS's Avatar
Would a dropped base work?
Old Feb 17, 2013 | 02:01 PM
ex-x-fire's Avatar
With the spacer ring.
Old Feb 17, 2013 | 06:08 PM
Jake_92RS's Avatar
Awesome. thanks a ton.
