Starting issues
Old Feb 18, 2013 | 03:50 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Starting issues
Hey guys need some help. I replaced my intake gaskets last week all went well with that. Now I'm having starting issues. I have noticed that it occurs when the car is hot. There is no click or attempt for the starter to engage. I can wait five minutes or thirty just depends on whatever is causing the issue. I have added a ground from the motor to the frame just in case it's a ground issue. I replaced the starter relay as well. None of this has helped. There is power in the car when the switch is on. I have looped the clutch starting switch, and the security is disabled. So has anyone ever had this issue or be able to point me in the right direction. My next step is to remove the starter and have it checked.
Old Feb 18, 2013 | 06:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Starting issues
Google "Chevy hot start problem" , well documented
The fix
https://www.thirdgen.org/solenoid
http://www.streetrodstuff.com/Articl...tart_Problems/
http://www.chevyhiperformance.com/te...x/viewall.html
Old Feb 18, 2013 | 09:25 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: Starting issues
Thanks will do. The starter has been on there for several years. Just found it odd to all the sudden start this after I did all that other work.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
