cams
Old Feb 21, 2013 | 06:29 PM
GC87's Avatar
Car: 1987 Formula Firebird
Transmission: auto that was the only option
Axle/Gears: Stock
cams
I was just wondering if anyone could tell me the difference between hydraulic and solid cams I have a 87 formula 350 so I think it has a hydraulic cam but im not positive. Im not planing on changing it anytime soon I would just like to know. Thanks
Old Feb 21, 2013 | 07:26 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: cams
http://www.stangtv.com/tech-stories/...raulic-roller/
That explains everything you need to know. What they didn't show was that solid rollers make much more power in higher RPMs than they tested, so the test was skewed in that regard. For a street car I would argue that the money is better spent elsewhere. Your car will not have a solid in it unless someone else before you installed one. In most street and strip cars, I would recommend a hydraulic roller. They're cheap compared to their solid counterparts and can still make excellent power for most builds out there. I personally use a solid flat tappet, and they're great cams provided you are willing to do the extra work to ensure they stay operating properly.
Old Feb 21, 2013 | 07:43 PM
GC87's Avatar
Axle/Gears: Stock
Re: cams
thank you for the info that helps alot
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
