Cam
Old Mar 3, 2013 | 10:04 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Cam
I have a small block Chevy it is a 377 and I am going to buy a camshaft and need some input it will have AFR195 heads performer RPM air gap intake and a T61 Turbo it has a 700R4 now but may be going with a 6 speed
Old Mar 3, 2013 | 11:25 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Cam
Will it be a street car? Solid roller, hyd roller, flat tappet? Thats a small turbo.
Old Mar 3, 2013 | 11:27 PM
Re: Cam
One or two turbos?
Old Mar 3, 2013 | 11:29 PM
Engine: LQ4 ls 6.0
Re: Cam
It will be a street car it will have a flat tapped cam for a street car I could go bigger on the turbo but it will be a little ways down the road
Old Mar 3, 2013 | 11:32 PM
Engine: LQ4 ls 6.0
Re: Cam
Originally Posted by skirkland1980
One or two turbos?
One
Old Mar 3, 2013 | 11:33 PM
Re: Cam
What's the turbine air ratio?
Old Mar 3, 2013 | 11:40 PM
Re: Cam
I can't recommend a cam because the turbo is too small. If you use two it would make for an unstoppable powerhouse. The only way one of those turbos would work is if you used the tiny cam and tiny heads and the biggest turbine housing you could find. Even then it may still be a restriction and make less power than a good naturally aspirated 377.
Engine: LQ4 ls 6.0
Re: Cam
Man I would have to ask my guy about that I'm not sure I will find out and post it
Old Mar 3, 2013 | 11:55 PM
Re: Cam
A T76 would work better.
Old Mar 4, 2013 | 10:10 AM
Engine: LQ4 ls 6.0
Re: Cam
I'm open to that that is what the guy had so that is why I was looking at that one
Old Mar 13, 2013 | 11:20 PM
Re: Cam
Any progress?
Old Mar 14, 2013 | 02:48 AM
1gary's Avatar
Re: Cam
Power adder or not the foundation starts here.So do read these very important links:
http://www.crankshaftcoalition.com/w..._compatibility
http://www.crankshaftcoalition.com/wiki/Quench
http://www.crankshaftcoalition.com/w...ose_a_camshaft
http://www.crankshaftcoalition.com/w...pression_ratio
There are more,but I don't want to get into info overload.Read all of it and post questions if you have any.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
