Emissions Stuff?
Car: Pontiac GTA
Engine: 5.7L TPI
Emissions Stuff?
I'm still completely new to the TPI type motors and i have absolutely no clue what this thing is and i'd like to know what it takes to delete it?
FYI i have not done anything to this car yet, i bought it after it's been sitting in a garage for almost 9 years.
Links and an explanation would be highly appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Emissions Stuff?
That is your air pump diverterr valve. You should have your memcal reprogramed if you remove it. You will also need a shorter belt when you remove the air pump and will need to plug the air tubes in the exhaust manifolds.
https://www.thirdgen.org/serpentine
Car: Pontiac GTA
Engine: 5.7L TPI
Now will this effect me negatively, positively or not at all?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If you have a visual SMOG inspection than it will not pass without it.
Also =
Diverter/bypass valve controls air flow through the exhaust system during a cold start to help reduce emissions
When removed, vehicle may experience rich exhaust during engine warm up, catalytic converter damage, premature oxygen sensor failure and/or excessive hydrocarbons in the oil causing internal engine damage.
Also =
Washing all that filth off your motor will have more effect than deleting THAT, just from the weight reduction.
Car: Pontiac GTA
Engine: 5.7L TPI
Engine: Lb9
Transmission: M20
if you are needing assistance with reprograming let me know
Car: Pontiac GTA
Engine: 5.7L TPI
LT1Formula
Oct 8, 2015 08:34 PM
