Quick question on these aftermaket slave cylinders
Car: 1986 Camaro Z28
Engine: 357
Axle/Gears: 4.11's 10 bolt
http://www.speedwaymotors.com/Push-T...nder,1944.html . I've seen a few of these online. Where could I bolt this to? Would I put this on he side of the motor?
Re: Quick question on these aftermaket slave cylinders
that's the slave cylinder. It is mounted on the side of the trans. There is a pushrod that goes in the end with the black rubber bellows looking piece. The pushrod pushes on the clutch fork. The master cylinder is mounted on the firewall and is connected to the clutch pedal.
