5.0 tpi peformance upgrade insight
Old Aug 28, 2013 | 05:23 PM
HowIroc97's Avatar
Car: 1985 Iroc Z
Engine: 5.0 TPI
Axle/Gears: stock
I recently purchased an 85 iroc w/original motor and trans(5.0 tpi and 700r4,unsure of read end specs).I've decided to stay with original motor,now I'm seeking guidance on best performance upgrades(cam,headers,exhaust,heads,injectors,etc. Is the edelbrock hi-flo tpi kit worth buying?,what are some good upgrade to 700r trans?My personal research showed that my engines horsepower is rated at 215 and torque around 225. So to get those numbers around 350+ would be ideal. $2500 budget(no procharger,turbo,or nos)
Old Aug 28, 2013 | 05:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 5.0 tpi peformance upgrade insight
I wouldn't spend much coin on the 305, headers / free flowing exhaust and upgrading from the 870 to the 165 ecm would be a good start.
Old Aug 28, 2013 | 06:18 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
You'll need a decent amount of money to get it to 350 hp. Headers and 3.42 gears are always a good start.
Old Aug 28, 2013 | 06:28 PM
Chad85T/A's Avatar
Car: 85 T/A
You'll probably never see 350+ HP with a NA 305 unless you spend some major bux, way more than it would cost you to build a nice 383 with more HP.
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
