Summit Racing gasket set...work on '89?
Old Sep 7, 2013 | 06:02 PM
UrbanCowboyDan's Avatar
Car: 1989 Camaro+ 2004 Crown Victoria
Engine: 5.0 (Camaro) 4.6 (Crown Vic)
Transmission: 700R4 and 4R70W
Axle/Gears: not sure.... 3.27 in the Ford
So just wondering, will this kit work an 89 Tpi motor that was converted to carburetor? Or Do I need a different kit? Thanks!
http://www.summitracing.com/parts/su...0/applications
Old Sep 7, 2013 | 09:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Summit Racing gasket set...work on '89?
Sure
but the valve cover gaskets are wrong ( if that is important to you )
Need gaskets for the center bolt covers , not perimeter cover included in this kit
FWIW ,
the intake manifold is the only thing that makes it a TPI.
With the TPI gone it is just another '89 SBC engine , so not worth mentioning what it "had" previously
Only causes confusion
69GTOby
Apr 18, 2016 02:34 PM
Mdenz3
Sep 17, 2015 08:36 AM
abray1
Sep 14, 2015 08:18 AM
hdis2002
Sep 8, 2015 02:52 PM
84 TA NV
Sep 6, 2015 08:02 PM
