Engine Swap Question
Old Oct 1, 2013 | 03:20 AM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
So I have a 1992 Camaro that I'm planning on doing an engine build with. It currently has the LO3 305 V8, and I want to build a 350 out of a genI sbc. I have a basic idea of what i want and need but i just am not sure if it matters if I have 1 piece rear main seal or a 2 piece RMS. Let me know which one I need if it matters, thanks!
Old Oct 1, 2013 | 07:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Engine Swap Question
Makes no difference but usually 1 pce RMS engines have or have provision for the more desirable roller cam.
If you have a choice for a similar cost, get the 1 pce version ,
being able to use a factory style roller cam setup will be a benefit ( way cheaper ) down the track depending
how far you want to mod the engine.
FWIW
The common '96+ L31 Vortec truck engine is a good starting point for a 350 build , often are 4 bolt mains as well .
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
