Car shakes in 5th
Old Nov 19, 2013 | 07:06 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Car shakes in 5th
When I am on the highway, I usually have to stay in 4th gear, because when I shift into 5th, and add any throttle it shakes pretty violently, if I am in 4th going 85-90 its fine, but if I shift into 5th at 70, 80 or 90, it shakes as I put my foot down on the gas. Any reason as to why this would be? Any help would be appreciated! Thanks!
Edit: It also seems to not want to accelerate for a moment while its going through this shaking process.
Old Nov 19, 2013 | 08:39 AM
Lynn1990IRocZ's Avatar
Car: 1990 Iroc Z
Re: Car shakes in 5th
any noise or whining while shaking? can it be felt or heard in any other gears just not as clearly?
Old Nov 19, 2013 | 09:04 AM
Annihilate's Avatar
Engine: 5.0
Noise. Id have to drive again. But no, I get, what I feel are normal vibrations in all the other gears. 5th gear is just really bad. Like, I feel an urge to downshift bad.
Old Nov 19, 2013 | 09:23 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
How about lower speed in 5th? Shift early at 45 and slowly speed up. When exactly does the shaking start? As soon as you shift or at a specific RPM/Speed?
Old Nov 20, 2013 | 11:55 PM
92g92's Avatar
Car: 1992 Camaro Z28
I've been having the same problem! If his is like mine, when I shift it earlier at around 45mph, it's a real lopey, heavy feeling vibration like a whomp whomp whomp whomp sort of thing. Goes away around 55ish and then picks back up again at 75ish, getting worse as the speeds increase. Mainly when I get on the gas and then when I let off it ebbs away but still shakes the dash a bit until the speed and rpms decrease a little.
Old Dec 2, 2013 | 07:37 PM
DKIRCH26's Avatar
Car: 89 Trans-am
Engine: 305 tpi
Axle/Gears: stock
Mine just started doing the same thing, and kinda feels down on power some.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
